It is currently Thu Aug 21, 2025 9:40 pm
 Post subject: Clayton 140 OSS
PostPosted: Fri Jun 21, 2013 5:52 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
After 15 yrs of use, it/s making a kind of clacking noise.Checked underneath, seems to run fine .Anyone else have this problem, or maybe you have had a similiar problem ? checked the net couldn/t find any info.Found out clayton is owned by htc now , sounds like the noise/squeak/clack is coming from the oscillating shaft. Thanks
 Post subject: Re: Clayton 140 OSS
PostPosted: Sat Jun 22, 2013 6:40 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Bearing?
John Lewis
PostPosted: Tue Jun 25, 2013 3:09 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Update , the motor asembly had to be pulled out total PITA , and the spindle shaft lubed with PB blaster unfreezes everything and 3in 1 oil on the main spindle shaft . Unbolted the 2adjusting bolts and tightened the twin v belts . Clacking and squeaking stopped . Just had to find manual to seperate the bottom assembly fom the top .
Users browsing this forum: TripodBob and 36 guests
